Results 1 to 9 of 9
    Mar 2013
    2
    Default Miller 200le need help
    I just bought a 200le and the guy told me it ran and welded so I went home and hooked jumper cables to the ground and starter and could only get it to turn partially over so I manually tried to turn the engine over and it will go about half way with ease and then hits a hard spot and will not turn anymore you can turn it the other way with ease untill it comes around to the same spot and it will not go any further any suggestions would be appreciated by the way it's an Onan. Thanks
    Oct 2005
    North Central Indiana
    782
    Take the plugs out and try to turn it through the bad spot.
    northern NJ
    1,882
    Take it back? You should of had him demo it or tried it yourself.
    MM250
    RCCS-14
    Mar 2013
    2
    Well I payed very little for it and I can scrap it and make more then I have in it. I think I can make something of it. I was just looking for some advise I'm very mechanically inclined I just didn't know if I had enough battery current going to it ( like if there is a safety ) in it not allowing it to turn
    Feb 2012
    226
    ​like they said take the plugs out and turn by hand if it does turn good you may have to set the valves to spec that's where I would start.
    It could be a broking connecting rod for one of the pistons. But if you didn't pay much for it might be worth fixing. I have a AEAD 200LE its 40 years old and runs very good. Good luck!
    Sep 2012
    seaford de
    406
    Quote Originally Posted by browniethewelder:304278
    Definetly agreed. I have a newer bobcat 250, a Lincoln sa200 and my aead. My aead is my go to machine. Love the bead that thing burns. And does well with gouging 3/16 copper clad rods. I would definetly fix it if its not more than around 1500 parts
    Quote Originally Posted by Gabbiema06 View Post
    Hi, just wondering if you found out what was wrong with your motor in your 200 le? Please let us know, thanks.
    Default william in nc
    take off clyinder heads could have nut bolt or something got dropped down carb, found out on mine that was the problem
