Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Mar 2013
    4
    Default Repowering a Bobcat 225 from Onan gas to Onan diesel
    Team,
    First post on this site.
    Probably should have thought of this site before I ever started down the road of this project.
    Fast pass: I traded myself into a Bobcat 225 that I knew had sat out in the weather. The air cleaner was non-existent, which meant that the Onan Performer engine was going to need some love.
    After checking on rebuild kits for the Performer, I tripped across a freshly refurbished 2 cylinder Onan diesel. Some guy had purchased a bunch of them from military surplus auction.
    Rotation of the diesel is correct for the Bobcat.
    I have yet to separate the Onan gas engine from the generation unit as it appears I need to pull both as a unit from the Bobcat frame and then remove the loooooong bolts that run from front of generation/power unit, through the back and into the Onan Performer.
    Although I am partial to diesel power, if the consensus is to stick with the Onan gas engine - I will whole heartedly listen. I am not interested in creating the next Batmobile - just looking to get this welder running.
    If gas: any recommendations for affordable rebuild kits on the Onan Performer?
    If diesel: any guidance/recommendations on how to come off the flywheel of the Onan diesel and connect to the power unit?
    From what I have briefly read, the Onan Performer has a tapered snout shaft that runs off "front" of engine.
    Under the statement that: Anything can be accomplished with enough money and time.......................I am - unfortunately - a little short on both right now. Any insight on best path from point A to running welder - would be great.
    Thanks in advance.
    Mar 2013
    4
    Default Doesn't anyone from Miller monitor this site?
    Team Miller,
    Surprising to me that a forum sponsored by the company and part of your website - isn't monitored by company personnel.
    My post/request has had 225 views. NOBODY from Miller spends time on this site?
    I could understand if it was an obscure welding forum - but my question was about a Miller welder.........posted on the Miller sponsored forum.
    Comment in any direction you want - just comment.
    I've got an old Lincoln tombstone arc welder. Perhaps I will see if I get any better response from the Lincoln team when I request help from them.
    When y'all are in your corporate meetings trying to figure out how to improve brand loyalty - may I suggest a discussion around replying to customers asking for help? I guarantee you it will go a long way. I am positive that you can find some consulting firms that will teach you how to say "hello" to a customer.......in exchange for a lot of money.
    Thank you so very much. My experience was great.
    Sep 2009
    South Carolina
    571
    I think its best to e-mail Miller. There are some guys on here who may be able to help but you'll have to wait until they log in and maybe have the answers.
    This site gets a good bit of traffic, most like myself wouldn't have a clue to what your asking. Just hang around awhile and someone will come along that knows how to help.
    Good luck
    northern NJ
    1,916
    Call Miller direct on the phone. Ask for the engine drive dept. You'll be able to talk to a tech.
    MM250
    RCCS-14
    northern NJ
    1,916
    ttahoe1 wrote --
    When y'all are in your corporate meetings trying to figure out how to improve brand loyalty - may I suggest a discussion around replying to customers asking for help? I guarantee you it will go a long way. I am positive that you can find some consulting firms that will teach you how to say "hello" to a customer.......in exchange for a lot of money. ----End quote
    Maybe if you contacted them direct instead of a post on an open forum? See below.
    MM250
    RCCS-14
    May 2011
    Bossier Parish La.
    560
    ttahoe1 wrote --
    Best suggestion yet to get a more timely response. This way they can address your questions more quickly for you. It would be a good idea to have the engine serial & model numbers handy when you contact them, along with any other info you can get off the engine data plate or other sources.
    May 2011
    Bossier Parish La.
    560
    Give them a call, what have you got to lose(except extended wait time for your answers)?
    Mar 2011
    102
    When and if you do get ahold of a Miller rep be sure and tell them how important YOU and your question are, bet they drop everything just to help YOU out.
    Feb 2012
    Wa
    656
    I hear the best way to get FREE answers is to complain about the speed in which you receive them. You could always do some ACTUAL research on your own to try to solve YOUR problem. But maybe all you know how to do is have people tell you what to do.
    Not saying you can't bump your thread for attention, I would just check your long winded generalized gripes you have with the world. Fact is nobody cares, you got yourself into this. Nobody here, even miller stands to make money from you, so be happy if you get any response, not upset when you don't. Just general forum etiquette.
    Oct 2005
    North Central Indiana
    782
    "If diesel: any guidance/recommendations on how to come off the flywheel of the Onan diesel and connect to the power unit?"
    I don't think Miller can get involved in such projects. To many things can go wrong, miller would be putting themselves square in the sights of a lawyer.
    I would think a welding repair business or small motor shop familiar with both motors would be the best place to get help.
