Results 1 to 2 of 2
    Default Tig torch parts ID help
    Hi at work we have a miller 350 or 400 amp tig I use occasionally my main job is a machinist. I would like to buy my own set of cups collets and lenses but the style of lenses found on EBAY are different than what work uses.I'm off work till the weekend so I dont have any part#s The lenses they use thread into the handle and have a shorter length with a large hex at the screen end. It is a water cooled torch that uses lenes like the weldcraft site shows for a wp18. Are the common parts on EBAY compatible if you use the collets and lenses and cups. Are the parts different because of the high amp capability of the welder. Is there online parts availible. Thanks
    Sep 2006
    Washington State
    73
    Default tig touch help
    go to CKworldwide.com. they have a online catalog. most welding suppliers should have access to their inventory.
    trailblazer 280 nt with 3000 hrs and running strong
    today I bought a new trailblazer 302
    and a new s-32p
    dynasty 200 dx
    maxstar 140
    passport
    XR pushpull
    spectum 500
    cutmaster 50
