I just bought the wireless hand control for my Trailblazer 302. I'll also be getting the wireless foot pedal for the tig torch.
Does each wireless device need it's own 14 pin receiver? Or can I just get the pedal and use the receiver I've already got with the hand control?
Thanks.
Results 1 to 10 of 10
Thread: Wireless Remote Question
03-17-2013, 09:50 AM #1
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
03-17-2013, 09:58 AM #2
I would think they are paired together. They don't seem to have a code to switch for different sub frequency.
Good question, hope someone has the real answer
03-17-2013, 10:38 AM #3
- Oct 2011
- 32
I don't own one but, in the manual it tells you how to pair devices to receivers.So seeing that, would think you could have a pedal and a remote with one reciever.
03-17-2013, 10:42 AM #4
- Oct 2011
- 32
http://www.millerwelds.com/om/o246022c_mil.pdf see pages 14 and15
03-18-2013, 06:12 AM #5
- Oct 2011
- 40
wireless control
Let me know how you like it. I have thought about getting one for a while now. Just hard to spend the money without knowing if I'll like it
ARMOR
MOBILE WELDING&SERVICES
Trailblazer 302
X-TREME 12VS
Spoolmatic 30A
Millermatic 135
WeldCraft WPseries TIG torch
Smith oxy set.
03-18-2013, 06:57 AM #6
Thanks for the feedback. After reading the manual, it appears that you can use one receiver for both transmitters. You would just have to make the receiver learn the new transmitter. Looks quick enough but would probable become a hassle in the field.
My bigger worry now is....... Page 8 of the manual shows the compatibility chart. The chart shows the foot pedal doesn't work with the Trailblazer. I hope that's a typo.Last edited by kvwall; 03-18-2013 at 07:05 AM. Reason: Changed page number
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Diversion™ 180
03-18-2013, 08:40 AM #7
- Jan 2012
- Marsden, sk. Canada
- 26
i had one for my pro300 and was not impressed. on my machine i lost 20% of my amp range. set my machine at 300 amp. turn my remote up and when it got to 80% i would already be at 300 amp. i got it replaced with another miller wireless. set at 300 amp, turn up the remote and i would hit about 80% the machine would show about 270-280 amps.the last 20% on the remote the amps on the machine would not move. so i returned that one as well.my lws inquired why they both worked improperly, miller said that was how they worked on the pro300. for $1000 they could afford to program the remotes for the different classes of their machines i would think. to top it off i got stuck with the restocking charge for the second remote. my rant for the morning.
03-18-2013, 09:19 AM #8
I just got an email from Miller stating the wireless foot pedal won't work on the Trailblazer. Seriously? So am I stuck with lift arc for Tig?
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
Diversion™ 180
03-18-2013, 07:01 PM #9
- Oct 2011
- 32
03-19-2013, 06:35 AM #10
