    Apr 2006
    TAXACHUSSETTS
    1,412
    Default Pintle Plate 3/4"
    Did this yesterday for a customer.Think its a 12 or 13 western star defintly brand new less then 1k on odometer.Holes for trailer plug glad hands inside frame.30 ton hitch.Keep lights behind plate slightly for protection somewhat.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    1,565
    If the glad handles & plug are inside the frame rails how do you access them? Are they above the plate in the dump body frame?
    Can I assume it's 1" plate? Any bracing in the lower section?
    Apr 2006
    TAXACHUSSETTS
    1,412
    In img 238 you see the 1" holes outside each tail light those are where the glad hands mount.I was refering to mounting just inside the c of the frame.Sorry bout the confusion.All 3/4" plate gussetts are 8"x8" that i cut off lower corners.Mounted off bottom of frame rail as typical but i did angle these inward more toward the pintle ring 4"in off sides of plate.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    1,565
    Thanks, I now see that the holes in the plate are for the air & electric. Can't believe I didn't realize that on my own.
    I just got called to move the pintles on two tandems. Need to fill in the holes (they are rotating pintles) & remount them up higher. The plates are 7/8" thick, weird size.
    Apr 2008
    245
    Looking at the pictures it appears that only the rail to plate welds and gussets are holding this together. Is that correct? Are the welds fillet or groove?
    Apr 2006
    TAXACHUSSETTS
    1,412
    Quote Originally Posted by HayFarmer View Post
    It,s welded across the dumps boss/hinge assembly.34"across whole top also.Some grooves, fillets on gussetts.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2008
    245
    Thx. What welding process did you use?
    Apr 2006
    TAXACHUSSETTS
    1,412
    Quote Originally Posted by hayfarmer View Post
    thx. What welding process did you use?
    smaw.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2008
    245
    thx!
