Results 1 to 3 of 3
    Feb 2013
    16
    Default 12 RC suitcase calibrate voltmeter? mine is off by 10x
    I have a suitcase wire feeder that the voltage meter is off by a decimal point. when it reads 2.8 volts it is putting out 28.0. Can I change this?
    Kelly
    I'm not an expert, but maybe the dip switches inside the machine are set wrong...
    look at page 21 of the manual...
    http://www.millerwelds.com/om/o1500_15ag_mil.pdf
    maybe the voltage display is set to read from the sense lead and no sense lead is used?
    Feb 2013
    16
    I will check the switch settings. Thanks
    Kelly
