I have this table. It is good for little things. Mine warps too and I expected that given the thickness of the table top...was surprised you were surprised about this as well...give you've surely warped thicker stock welding it already. It is what it is...basically a portable, fully adjustable table that is conductive, fire resistant and light duty...for light duty work. I like mine despite the sweet shape shifting it does while using it.as somwone mentioned...if you have the space....it is a tremendous opportunity to build a true welding table with a thick top side....with drilled slots to clamp thru yadda yadda yadda....far as cust service goes.....unless the co is built with it in their culture its simply a low paying, high turnover job filled with dbags that are angry and rude......which is ironic to the position title itself! Good luck!
Results 21 to 30 of 33
03-17-2013, 10:39 AM #21
- May 2012
- 106
Miller Thunderbolt 225 AC/DC
Millermatic 211 Auto/MVP
03-22-2013, 12:19 PM #22
Update on Strong Hand Tools customer service. They sent me a replacement Nomad table top which arrived today. I'm not sure if this post had any play in that, but the bottom line is that once I was finally able to contact them, they took care of the problem rather quickly. I appreciate their efforts and will gladly purchase from them in the future.
03-22-2013, 05:42 PM #23
- May 2012
- 106
Hey - that's pretty impressive/interesting. but is the table top the 'same' structurally as the other?
I've been thinking about this a bit - perhaps - since you have a 'set' now - if you take the "old" top and once off - weld up some flat stock on the bottom of it - like an 1/8" thick, 1/2" wide piece of flat with the 'short edge' against the bottom of the table it'd stiffen it up quite a bit for you. Will add some weight to it but....would be a nice alternative and/or second table top to the frame you'll be welding up for it using the replacement!
03-22-2013, 06:32 PM #24
The tops are the same 14g. Looks like nothing's been changed. They claim that they have not had this problem with any other customers...that my tabletop is the first to warp.
What you suggest is very similar to what I had in mind. That sounds like it should work just fine. I was going to just get a 1/4" plate to mount to the top but I think I'll try the supports first. That way, I'll be able to still use the slots for clamping.
I really do like the portability and design of the table, although I still want to see Miller's version up close. I don't think that the supports would add too much weight to the table. It should still be "portable". It's pretty lightweight now so a few extra pounds shouldn't hurt. Much lighter than a 1/4" tabletop for sure.
I appreciate the comments and suggestions. Thanks...
03-23-2013, 06:50 AM #25
- May 2012
- 106
Hey - as I have the same table and somehow - have the 2nd table in the history of that table to warp when used
- would be interested if you don't mind in seeing you're final product and results - I might do the same thing to stiffen mine up......errrrrrrr - so to speak! Perhaps you can PM me a picture or something after you've done it if you don't mind....thx.
03-23-2013, 07:04 AM #26
Maybe you should change the title of the thread? It seems to me that with in two weeks you had a new top without having to send the old one in. That seems like pretty good customer service to me.
Hope it works out for you.MM250
03-23-2013, 07:10 AM #27
03-23-2013, 07:13 AM #28
03-24-2013, 09:08 AM #29
- Oct 2005
- Summerville SC
- 191
I've got the same table. It has it's limitations but will do 95% of my jobs. This table folds up nice because space is limited here. I got in on sale at Northern Tools. It came with a nice clamp and some ok magnets. People get confused with the term "welding table" expecting a strong, beefy table. That it's not.
Wheat Stalker
Millermatic 210
Fisher CZ-5...CZ-3D..
Trek 5500
1966 Amphicar
03-24-2013, 10:34 AM #30
They must have quit making them as they aren't on the website.
http://www.stronghandtools.com/
Their other welding tables are pretty impressive...BobBob Wright, Grandson of Tee Nee Boat Trailer Founder
