Results 11 to 20 of 33
    1,589
    So the table I think you have spec sheet says it is only 14 ga. thick top. No wonder it warped.
    Real welding tables are thick to avoid warping. If they send you another top it will warp also from the heat. 14 ga. will never stay flat in a welding environment. You did nothing wrong other than assuming it would not warp.
    Dec 2011
    247
    If you really want a welding table that won't warp consider a cast iron platen but be sure you are sitting down when you ask the price. search for "welding platens" on the net. Or you could go down to the scrap yard that is buying all the storm drain grates that are disappearing out of the streets and buy one of those.
    Meltedmetal
    Jan 2013
    NE Illinois
    146
    What's that all about I wonder?
    Mar 2011
    st-eustache qc.canada
    106
    Sorry homer for the confusion, i was just pulling your leg... saying that now you can weld hotter and longer due to your clean air in your shop.
    You' re probably now too much of a welder for this hobbyist table wich is pretty light gauge as others said.
    Jan 2013
    NE Illinois
    146
    I actually felt the tug on my leg. That may very well be part of the problem...I'm growing up. Now I can work at the big table!
    Jan 2013
    NE Illinois
    146
    I just received an email from Gary at Strong Hand Tools. He apologized for customer service not getting back to me. He also said that this was the first time in several thousand sales that he has heard of this problem. He assured me that their engineering dept. will look into this so that they may avoid any future problems. He has offered to send me out a new top for the table. Maybe just a coincidence, but I wonder if they saw this post?
    Aug 2004
    Milan Michigan
    1,423
    Homer Sapien, If your table is indeed only 14 Ga. it will always warp, Buy yourself a 1/4" plate.
    Jan 2013
    NE Illinois
    146
    I know you are right. I will use the table for very light duty things and come up with something else for the more robust projects...
    Sep 2009
    South Carolina
    380
    I might buy one of these to hang in my trailer. I'm confident they will warp laying a weld flat right on top. I could see where one might come in handy out on a small tig project tho.
    I might build a similer table out of some thick aluminum also. Got to keep the weight down.
    Jan 2013
    NE Illinois
    146
    The part that really baffles me is that it is called a "welding table", but I guess you can't really do much "welding" on it.
