Results 1 to 10 of 19
    Dec 2010
    Baltimore
    11
    Default Engine driven welder
    Goodmorning, Long story short I just got married last November and moved into a old farm house that my wife already owned. It only has 100 amp service snd while I do have room in the breaker box it would be a long run to get 220v out to my shed. I weighed the fact that we may not be staying in this house forever and the price of the electrical components, I decided a engine welder would best suit my needs.
    Basically I'm just looking for some opinions on wich one to get. My budget would be right around 2500 and I would be using it to run my mm211 and hypertherm 30 as well as 7018 rod for heavy stuff. I also like the portability of them too. Miller and maybe Lincoln would be my only choices. Thank you
    6,750
    $2500 is nothing welder wise. Best to look at a generator.
    Sep 2012
    seaford de
    333
    You can get a pretty decent used welder for 2500 easy.
    Illinois
    458
    Is this near you ?? http://harrisburg.craigslist.org/tld/3649283647.html
    Welder, Miller Bobcat - $2875 (Lancaster)
    Product Description: Miller Electric Mfg Co 907209 225 Welder/Generator With 23HP Kohler Engine And Standard Receptacles, 10000 Watts Peak, 225 Amp MLR1177.Brand new in box. Never started. Model # 907209
    it's NOT ok to contact this poster with services or other commercial interests
    Posting ID: 3649283647 Posted: 2013-02-28, 10:48AM EST email to a friend
    Avoid scams, deal locally! Do NOT wire funds (Western Union, Moneygram). Beware cashier checks, money orders, shipping, non-local buyers/sellers. More info
    Used would be my suggestion,
    but if you want new, a miller wildcat is only a little over your budget.
    it only has 6500 watts peak of generating power, so it may not run you pm30 or mm211 at full power.
    I recently saw a 3 year old bobcat 225 with less than 400 hours on Craigslist for $1900, but your location my demand more, idk.
    Oct 2005
    North Central Indiana
    615
    You need clean power to run your welding equipment. I would be hesitant buying an older welder/generator.
    Illinois
    458
    Quote Originally Posted by tackit View Post
    Here's answer from MILLER on a previous thread by someone.
    In an older post I was asking about using gen power/ THD with the 211. Thought I would share what Miller said about it.
    " The Millermatic 211 is pretty forgiving when it comes to input power. As long as you have a generator that is providing roughly 60Hz power and at least 7,000 watts continuous 230 volt power the unit will be fine."
    http://www.millerwelds.com/resources...=211+generator
    Aug 2004
    Milan Michigan
    1,418
    Lincoln and miller are both good, But I would look for at least 8,000 cont. power, If you wait long enouph you can find a Bobcat or Trail blazer that kicks out 10,000 surge and 9,500 cont.
    But watch out because theres a difference between surge and continuouse, You need to concentrate on cont.
    Dec 2010
    Baltimore
    11
    Thanks for your input fellas. I have been been keeping my eye out on Craig's list and there have been a few trailblazers and bobcats that were in my price range. Im just not sure what I'm looking for buying used. My neighbor works on small engines and generators so I'm sure he could fix or rebuild any of them if need be. Thanks again
    Dec 2010
    Baltimore
    11
    I did find a older 250G but it doesn't look like it hase a 220 output on it
