Results 1 to 3 of 3
    Feb 2013
    NJ
    19
    Default Multimatic 200 Tig & Mig Question
    This is directed at the Miller guys as I'm sure they would have the correct answer rather than a guess or an opinion....Is there any problem leaving the Mig wire connected inside the cover while also having the Tig wire connected?Does the selector switch cut power to the Mig connector when the switch is set to Tig? I ask because the way things are setting up, the cover is going to be against a wall and I don't want to have to move the machine to open the cover every time I switch from Mig to Tig which is often enough.
    Multimatic 200 w/ Tig kit & Spoolgun
    Victor Torch
    Accumulating as I go
    Jan 2012
    Appleton, Wisconsin U.S.A.
    141
    The machine will only provide power to the appropriate dinse connector on the front of the machine. When the cable that goes to the drive is disconnected from the front to TIG weld, the drive casting canít get any power. It boils down to you can leave both connected without having any problems.
    Feb 2013
    NJ
    19
    Thank you sir
    Victor Torch
