Results 1 to 7 of 7
Thread: plasma cutter
    Jan 2013
    Ohio
    22
    Default plasma cutter
    Just seeking opinions on what size plasma I should get....primarily do repair and maintenance ....I'm leaning towards the Hyperthurm Powermax30...thanks for your opinions in advance
    WY...armpit of U.S.A.
    636
    You really are too sparing in your description of your needs for a plasma cutter. Saying you'll be doing primarily repairs and maintenance can mean you work on repairing and maintaining RC car bodies or heavy earthmoving equipment. I'm happy with my Hypertherm. It seems to be a good machine. If the Powermax 30 fits your needs I would say go for it.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    Well, if you think you will not need to ever cut above 1/2 inch and may need to use 110v and 220v power, then I would say that the P-Max 30 is the machine. But, if you will need to cut more than 1/2 inch and you will never need 110v power, then I would say get the P-Max 45.
    As another thought. If you ever do work with stainless or aluminum, you will want the extra power, trust me.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Illinois
    459
    Go for the 45. Buy it once and have the power when needed.
    The 110/220 voltage is a nice feature. I did hear rumors that the future 45 maybe going to 110/220. That would really make the 45 sweeter.
    Jun 2012
    16
    The thickness you need to cut is essential to know; 1. What thickness of materials do you cut 80% of the time, 2. What is the max thickness you need to cut (edge start ok) and what thickness to pierce. 3. What type of power is available (single or three phase, what voltage, what amperage). There are many makes and models and power levels available.
    Jim
    Quote Originally Posted by kerr74 View Post
    wisconsin
    113
    I agree. You may need more power at some point. The 45 is really not that much more.
    Nov 2010
    Central Kalifornia
    63
    Default Plasma
    I looked at both the 30 and the 45. I compared the cost and considered a few other factors. I ended up with the 45. Since I have gotten the toy (yes I am a hobbyist) I have not moved, attached hoses to or even look at a cutting torch. If you are doing lots of repairs go for the largest machine you to afford.
