guys,
we have a small project at work we will be tig welding which is made from .125" thick sheet metal, the alloy is 5052 aluminum.
i searched the internet and see its safe to use 4043 or 5356 filler, which we already have in the shop.
do you guys agree with this ?
and is there anything special i should look out for when welding this type of aluminum ?
thanks for any input, since i have never welded 5052 before.
Results 1 to 10 of 13
03-14-2013, 04:10 PM #1
- Nov 2006
- 350
Tig welding 5052 Aluminum. which filler ?
SyncrowaveŽ 200
Lincoln AC/DC 225/125
Lincoln Weld Pak 100 wire feed
03-14-2013, 06:40 PM #2
- Jan 2013
- 15
Either filler is good unless you are anodising it then go for 5356.
4043 will be more ductile and less likely to crack but on the other hand 5356 is a stronger material but tends to crack if you don't cap the weld properly.
03-14-2013, 09:43 PM #3
- May 2007
- Los Angeles
- 116
5052 is also used a lot in marine applications. if it was going to be exposed to the elements i would use 5356. But as stated before either will work.
03-15-2013, 02:28 AM #4
- Nov 2006
- 350
thanks for the help guys.
since it wont be getting anodized, i will go with the 4043 to stay away from the cracking...
again, thanks muchSyncrowaveŽ 200
03-15-2013, 07:24 AM #5
- Jan 2011
- 24
It would help to know what the project is. If it is something that is going to experience high temperatures, 4043 would probably be better. If it is something that needs maximum strength, 5356 would probably be better.
03-15-2013, 09:06 AM #6
5356 is actually more ductile, whereas 4043 may be a little softer, but will fatigue much faster than 5356 or 5183. I would never use 4043 on a seam that experiences vibration or variable loads.
If you are welding 5052 sheet into a tank, you are much better of with the stronger filler. Personally I choose 5356 every time unless elevated service temps are experienced.
Lately I have been using Maxal's 4943. Lightning fast for tig work, and bridges the gap in the strength area. Wets like no tomorrow.Last edited by shovelon; 03-15-2013 at 10:52 PM.
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
03-15-2013, 11:36 AM #7
Member
- Mar 2012
- 38
So there are some people using 4943. Shovelon have you been using it for just tig or mig also? Also what type of application? I've talked to my lws about bring some in for use on 6061-t4&6 plate for making race snowmobile engine mounts. From what I've talked to maxal it should be the cats a$$ after post weld tempering.
03-15-2013, 05:20 PM #8
- Nov 2006
- 350
i hope to one day have the knowledge you guys have....
thanks for all the inputSyncrowaveŽ 200
03-15-2013, 07:13 PM #9
I haven't seen the 4943 on the AlcoTec Filler Alloy Chart, what alloys is it most compatable with? Going to have to do some research on this filler.
Diversion 180
Millermatic 350P, XR-Aluma-Pro
30A Spoolgun
Lincoln Power Mig 180
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution 360
40 ton press brake
Shop full of tools
03-15-2013, 10:51 PM #10
I have been using it with both mig and tig. I really like the tig rod. It flows like water and is fast. It is very strong too. I am hoping to phase out my 4043 tig rod soon. My LWS said they will stock it too.
As far as mig, it is watery in the flow characteristics, and lays a virtually smut free strong bead. The wire is shockingly brittle but drives nice in the 350p. I won't be switching from 5356 mig wire though as I have that down pat, smut and all.Nothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
