Results 1 to 10 of 13
    346
    Default Tig welding 5052 Aluminum. which filler ?
    guys,
    we have a small project at work we will be tig welding which is made from .125" thick sheet metal, the alloy is 5052 aluminum.
    i searched the internet and see its safe to use 4043 or 5356 filler, which we already have in the shop.
    do you guys agree with this ?
    and is there anything special i should look out for when welding this type of aluminum ?
    thanks for any input, since i have never welded 5052 before.
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Jan 2013
    15
    Either filler is good unless you are anodising it then go for 5356.
    4043 will be more ductile and less likely to crack but on the other hand 5356 is a stronger material but tends to crack if you don't cap the weld properly.
    May 2007
    115
    5052 is also used a lot in marine applications. if it was going to be exposed to the elements i would use 5356. But as stated before either will work.
    346
    thanks for the help guys.
    since it wont be getting anodized, i will go with the 4043 to stay away from the cracking...
    again, thanks much
    SyncrowaveŽ 200
    Jan 2011
    24
    It would help to know what the project is. If it is something that is going to experience high temperatures, 4043 would probably be better. If it is something that needs maximum strength, 5356 would probably be better.
    Aug 2010
    1,097
    Quote Originally Posted by IanHerbert View Post
    5356 is actually more ductile, whereas 4043 may be a little softer, but will fatigue much faster than 5356 or 5183. I would never use 4043 on a seam that experiences vibration or variable loads.
    If you are welding 5052 sheet into a tank, you are much better of with the stronger filler. Personally I choose 5356 every time unless elevated service temps are experienced.
    Lately I have been using Maxal's 4943. Lightning fast for tig work, and bridges the gap in the strength area. Wets like no tomorrow.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    So there are some people using 4943. Shovelon have you been using it for just tig or mig also? Also what type of application? I've talked to my lws about bring some in for use on 6061-t4&6 plate for making race snowmobile engine mounts. From what I've talked to maxal it should be the cats a$$ after post weld tempering.
    346
    i hope to one day have the knowledge you guys have....
    thanks for all the input
    SyncrowaveŽ 200
    Mar 2011
    La
    172
    I haven't seen the 4943 on the AlcoTec Filler Alloy Chart, what alloys is it most compatable with? Going to have to do some research on this filler.
    Diversion 180
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Power Mig 180
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
    Aug 2010
    1,097
    Quote Originally Posted by Manisoba View Post
    I have been using it with both mig and tig. I really like the tig rod. It flows like water and is fast. It is very strong too. I am hoping to phase out my 4043 tig rod soon. My LWS said they will stock it too.
    As far as mig, it is watery in the flow characteristics, and lays a virtually smut free strong bead. The wire is shockingly brittle but drives nice in the 350p. I won't be switching from 5356 mig wire though as I have that down pat, smut and all.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
