    Mar 2013
    10
    Default Miller maxstar200
    I am getting no high frequency. When I checked the spark gaps I am getting a sparks. from there it goes through a transformer. Can anyone help out on troubleshooting this problem?
    8,180
    sure, whats the serial#??
    Mar 2013
    10
    Default Serial #
    lb165701
    8,180
    Coupling coil may have cracks, not hard to see in a semi dark area, cover off, and hf engaged. Or bad torch cable. best to take the unit in for the prepower check list.
