Results 1 to 5 of 5
    Default Diversion 165 and 50 amp service
    Hey folks,
    I'm current in transition of living quarters and need a garage for tools and storage. I also want to be able to set up a small shop. I have found a local storage facility. (Anchor Storage) that offers a unit that is 15'x45' with 50 Amp service.
    Is this enough to power my Diversion 165?
    Los Angeles
    2,971
    Yes, that will be fine for the 165
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Apr 2010
    324
    30 Amp, 240 Volt is plenty. When they say "50 A service", I hope that's not two 15A and one 20A at 120V.
    Do they actually allow welding?
    It was as advertised.
    It is a 15x45 Storage unit with two different connector for the 220. I was impressed. I think I will probably get the unit for a couple of months.
    Nov 2012
    Northern Arizona
    571
    Whoops, you have a double post and I responded in the other thread. You're good.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
