Results 1 to 7 of 7
    Nov 2011
    Rock Springs, WY
    Default MM211 autoset with spoolmate 3035 and sga 100
    Was wondering if anyone knows if a 3035 spoolmate and a sga 100 would work with my 211?
    Oct 2005
    North Central Indiana
    615
    duplicate post
    Oct 2005
    615
    cyberweld says similar welders. http://store.cyberweld.com/sga100spoolg.html
    May 2011
    Bossier Parish La.
    384
    I think with the MM211 the SGA 100 is not needed for the 3035 SG. I have the SGA100 for that spool gun on my MM140 W/O auto-set, but don't think it is needed on the MM211. Not 100% positive, but pretty close. It should be mentioned in your owners manual, what it takes to hook it to your machine.
    Dec 2012
    Sweetwater, TX
    194
    I believe the 211 uses the spoolmate 100. Here is shows its a direct connection.
    Millermatic® 140/180/211/, Passport® Plus All Serial Numbers Spoolmate™ 100 Series Direct Connect;
    For the Millermatic 140/180, prior to serial #LH210051N, use retrofit kit #300409
    No spoolgun solution available for the Millermatic Passport, must upgrade to the Millermatic Passport Plus.
    I don't see anything about connecting a spoolmate 3035 to the 211.
    Here is the chart.
    http://www.millerwelds.com/products/...gun-chart.html
    Nov 2011
    Rock Springs, WY
    Default Thanks
    I was hoping it would work..really want to get one and there is a whole set up for sale for about 350.00. Guess I will have to see about the spoolmate 100.
    Thanks everyone for your input!
    2,634
    Quote Originally Posted by Wolfwalker View Post
    Dunno why you wanna spend $350.00 when you only have to spend $234.00
    http://store.cyberweld.com/sp100migsp.html
