Thread: Radnor E3's
    Feb 2013
    NJ
    16
    Default Radnor E3's
    Went to the LWS to get some 2% Lanthanated and they didn't have any but the guy showed me some E3's from Radnor...supposed to be good for both AC & DC...AWS Spec. A5.12M/A5.12:2009...AWS Class EWG...Color Code: Purple...Chemical Specs:98.34% W + 1.5% La2O3 + .08% ZrO2 + .08% Y2O2...they are non radioactive and claim a longer life....anyone ever use them? Here's a website for um... www.e3tungsten.com
    Multimatic 200 w/ Tig kit & Spoolgun
    Victor Torch
    Accumulating as I go
    Mar 2013
    13
    Been using 3/32 E3, OKI Bering brand for a couple of weeks in a WP17 torch @ 162 amps AC on aluminum. Compared to ceriated it forms a more stable ball and spits a lot less owing to that. Costs me about seven bucks more per 10-pack at the LWS.
    Haven't tried it on steel yet.
    Dynasty 350
    Syncrowave 200
    Maxstar 150S
    Titanium 9400
    Purox O/A
    Cutmaster 42
    Aug 2010
    1,099
    Conventional chinese triple mix or "Rare Earth Blend". Diamond ground products makes the best "TriMix" but the prices are out of this world.
    1.5% lanthanum
    .08% zirconium oxide
    .08% yttruim
    Save your money and buy 2% lanthanated. Great on alum, but not quite as good as thoriated on steel.
    HTP usaweld has the best prices for tungstens. Other than NOS off epay.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Feb 2013
    NJ
    16
    I don't have a set-up to do aluminum...all steel...I had heard that the lanthanated was better than the thoriated on steel....I ended up picking up a pack of the E3's cause I needed to finish something...the tip lasted a lot longer than the ceriated I've used and I'm just startin out so you can imagine how many times the tip hits the steel...The only tungsten I've used is the one that came with the Multimatic 200 Tig kit which I believe is ceriated
    Victor Torch
    Aug 2010
    1,099
    Quote Originally Posted by Hammer65 View Post
    Ceriated is pretty good on alum. Much better than thoriated. I find the opposite with steel.
    So far I have found no wonder tungsten. Some day perhaps they will take away thoriated, which is why I have several hundred in reserve.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
