Results 11 to 17 of 17
    Sep 2009
    South Carolina
    360
    Default Making a cart
    Decided to make a cart instead, first one so its kind of a do as I go thing. Not finished but will hold way more weight than the tires will allow.
    Aug 2010
    1,098
    I like that.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Sep 2009
    South Carolina
    360
    I like that.
    Thanks, I put the handle on today. Can't make up my mind where to mount the welder. I can stand on the corners, it doesn't tip. Just seems weird to have it in a corner but that opens up more bed room.
    Thinking about a rail across the back maybe a couple feet high to hang grinders and things from.
    Anybody have any suggestions as to what add ons would be beneficial?
    2,634
    The Fire Extinguisher is going to bounce out of the cart traveling down the road and wreak havoc inside your trailer.
    I would suggest a Roll cage-(Square or round tubing) around the cart- as it sits there is no way to strap it to the side of the Trailer wall.
    Just FYI on carts:
    with 2 swivel wheel you push
    with 4 swivel wheels you pull.
    You didn't post up a pic of the handle but I would make the handle at the rear of the cart, which will require you to move the swivel wheels to the rear also.
    Hard to tell the dimensions but make sure it fits through a standard door- if you see yerself working inside somewhere.
    Sep 2009
    South Carolina
    360
    Just FYI on carts:
    Hard to tell the dimensions but make sure it fits through a standard door- if you see yourself working inside somewhere.
    I just sit the fire extinguisher there, don't know if I would be carrying that one. It holds a good bit of water but a little red dry chemical maybe better and have the larger close by.
    I like the idea of a cage but why can't you pull two swivel wheels in the front with a handle long enough so you don't run over your heels? if I cage it, I can push or pull. I guess your stating the standards, thanks.
    Its 31" wide 48" long. Should fit through most doors, mine anyway.
    Thanks again for the ideas
    2,634
    If you have a long handle like a wagon then yes but the wheel geometry works a little differently , but for carts with swivel castors usually much easier to steer the cart by pushing.
    Oct 2005
    North Central Indiana
    615
    I've always wanted to buy an old Ford Ranger or Chevy S10 and make it into a flatbed, put a gas drive on it, something small for on the property and to help my farm neighbors out.
