Results 11 to 13 of 13
    2,635
    Quote Originally Posted by WyoRoy View Post
    For home use air is not okay. TIG, or GTAW, welding uses an inert gas, typically Argon or Helium, as a shielding gas.
    A 30 amp 230v circuit will work for the Diversion 180, per the online owner's manual. Miller offers quite a lot of useful information if you will take the time to look in the Resources section at the top of the page.
    Air Cooled Torch- Knucklehead
    New Jersey
    779
    Well, it depends what you have for a power supply. If you have 220 then I recommend an older Miller dialarc HF (Airco had the same one rebranded). Can be had for under $1000 used. I have a Diversion 165 which is a good hobby welded but now that I am doing more side work I would prefer something with ATLEAST a balance control and gas flow controls. Syncrowaves are good but draw a bit of power.
    Feb 2013
    24
    Thanks all...and darn auto correct (tight = tig). I see quite a bit on the Everlast equipment. Offshore which always bothers me and when I do spend more I'm never disappointed. But wondered for a entry level tig with some growth use...Everlast on the list at all?
    Regardless I'm thinking Miller as the 211 I bought is oh so nice a welder. And as the wife says...color matches my eyes???
