Did this yesterday for a customer.Think its a 12 or 13 western star defintly brand new less then 1k on odometer.Holes for trailer plug glad hands inside frame.30 ton hitch.Keep lights behind plate slightly for protection somewhat.
Results 1 to 9 of 9
Thread: Pintle Plate 3/4"
03-17-2013, 09:48 AM #1
Pintle Plate 3/4"
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
S-32 FEEDER W/1260 IRONMATE FC/GUN
HT/PWR-MAX1250 PLASMA
03-17-2013, 12:25 PM #2
If the glad handles & plug are inside the frame rails how do you access them? Are they above the plate in the dump body frame?
Can I assume it's 1" plate? Any bracing in the lower section?MM250
RCCS-14
03-17-2013, 01:10 PM #3
In img 238 you see the 1" holes outside each tail light those are where the glad hands mount.I was refering to mounting just inside the c of the frame.Sorry bout the confusion.All 3/4" plate gussetts are 8"x8" that i cut off lower corners.Mounted off bottom of frame rail as typical but i did angle these inward more toward the pintle ring 4"in off sides of plate.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
03-17-2013, 06:21 PM #4
Thanks, I now see that the holes in the plate are for the air & electric. Can't believe I didn't realize that on my own.
I just got called to move the pintles on two tandems. Need to fill in the holes (they are rotating pintles) & remount them up higher. The plates are 7/8" thick, weird size.MM250
RCCS-14
03-19-2013, 07:35 AM #5
- Apr 2008
- 245
Looking at the pictures it appears that only the rail to plate welds and gussets are holding this together. Is that correct? Are the welds fillet or groove?
03-19-2013, 08:12 AM #6
03-19-2013, 08:23 AM #7
- Apr 2008
- 245
Thx. What welding process did you use?
03-19-2013, 11:52 AM #8
03-19-2013, 12:04 PM #9
- Apr 2008
- 245
thx!
