Results 1 to 6 of 6
    Mar 2013
    1
    Default Trouble shooting push pull gun
    I have a 3 year old miller 252 and I just got a 25' push pull gun for it. I hooked it up, and when the trigger is activated, it feeds about 2" of wire, and then quits. The display shows this: hlp 005. I can't find my welder owners manual, can anyone tell me what this code is indicating?
    Also, any tips or suggestions on general use of pushpull for someone who has never used one would be appreciated. Thanks
    Oct 2009
    Northern ND
    17
    Aug 2010
    Los Angeles
    1,184
    Yes, the primary drive motor in the cabinet is overdriving, hence the help5 code. We get that on our mm350P if we overtighten the clamp springs. Loosen them and see if the 2 motors sync up. I guess the idea is to let the pull motor do most of the work, with the push motor as an assist.
    There is a SUP value labeled on the torch. Does your machine need to have that value inputed in the controls?
    Good Luck.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2010
    Los Angeles
    1,184
    Quote Originally Posted by OHT View Post
    Good.
    Page 30.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Oct 2004
    Edmonton, Alberta
    8,351
    The push motor really doesn't do much after the wire is loaded. I loosen it off to near no pressure, Then it feeds fine,
    Appleton, WI
    424
    In this type of situation the first thing I always suggest is to stretch the gun out straight, run a little wire out so you can grab it and then release the drive rolls in the unit and in the gun. After releasing the drive rolls try to pull the wire through the gun by hand, you should be able to pull it fairly easy, if you struggle to pull it the unit is going to struggle as well and you will want to check the spool brake tension and consider replacing the liner as well.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
