Results 21 to 30 of 36
  1. #21
    Houston, TX
    812
    Gotta love getting answers straight from the horses mouth! Just love the level of customer support miller provides!!!
    And Hypertherm.
  2. #22
    Jan 2013
    NE Illinois
    145
    Being used to the Hobart welders (HH140 & 210), I found the rear switch on the Multimatic 200 inconvenient at first. Now, I find myself looking for the switch in the rear for my AirForce 250 plasma cutter and then remembering...it's in the front. I'm so confused!
  3. #23
    Dec 2012
    52
    Quote Originally Posted by Miller Kevin View Post
    In some cases the reason could be a simple lack of space on the front panel to properly locate a power switch. Another possibility is that routing the leads through the unit could cause problems with weld performance because of noise on the lines in particular on inverter based units. In other cases the size of the machine itself may not allow for proper clearances for the primary leads to be routed through the length of the unit and still pass a 3rd party certification such as NRTL/C, CSA or UL. These types of certifications are very important for this equipment, without them we would not be allowed to sell in some markets.
    OK But none of those applies to the 211. Did you look at the pics I posted?
    As for relocating the switch on the Millermatic 211 to the front panel I would not recommend it as it could be a potential safety issue and would also jeopardize your machine warranty.
    Drinking lemonade near the welder is a potential safety issue. Using an auto-darkening lens instead of a true shade is a potential safety issue. Welding is a potential safety issue.
    The point is: if Miller built the machine with the switch on the front, it would be as safe as anything else about the machine. So the safest thing for Miller customers is for Miller to revise that design so we don't have to do it ourselves. If it takes a relay in the back & a low-current switch on the front, DO that. Personally, I don't think that's necessary on the 211. I think longer factory wires would pass any standard of safety & performance. What are we talking about - another $1-30 worth of parts on a $1000 machine?
    Quote Originally Posted by jimcolt View Post
    The switch has to be closw to the power cord entrance so long lengths of input AC power are not exposed inside the unit.
    I don't doubt for a moment that you know what you're talking about, and that there's some regulation mandating your switch location. But you worded that wrong... "Exposed inside" doesn't make sense. Wires inside a machine case are less-exposed than those outside, so if a long power wire is an issue, the external cord would be the larger problem.
  4. #24
    Mar 2011
    st-eustache qc.canada
    106
    Who the h**l woke-up those certification guys at ul and csa who slept all these years letting manufacturer put the switch where it belongs?
    Now i'm scared of my machines with front panel switches hope my laptop is not on their list
  5. #25
    Wa
    317
    Guess I don't quite understand where any confusion is, a miller rep just cleared the issue why some units have the switch poisoned at the rear of the machine.
  6. #26
    Nov 2012
    Northern Arizona
    268
    If you are referring to Jim Colt he works for Hypertherm... Not miller. Just to clear up any confusion! Cope was referring to it, but I think most people missed it.
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
  7. #27
    Wa
    317
    No, miller Kevin.
  8. #28
    Nov 2012
    Northern Arizona
    268
    Whoops, I went back and saw that post now. Ok, sweet! Also a good explanation. My ADD kicked in and I skipped it.
  9. #29
    Dec 2012
    52
    Here's another cheap effective solution: the electrical switch can be at the back safely certified INSIDE the case, and a safe certifiable inexpensive pushrod mechanism can link it to a front-panel button/knob. Home stereo amps have been built that way for decades.
  10. #30
    Wa
    317
    Quote Originally Posted by Steve83 View Post
    Your right Steve, they could do that. But they don't...and I'm sure it is because a mix of all the reasons listed in this thread. Mostly I'm sure the bean counters would not authorize that costly of a modification (only a few bucks), auto manufactures have engineers quibble over fasteners which cost cents, and that is for a 20k+ vehicle. Surely $1-3 of parts on a $900 welder is out of the question, especially if it is not necessary.
    Also, I would be more frustrated if that front switch failed because some janky remote rod system had been implemented, instead of just putting a regular switch located somewhere else on the machine.
    I don't necessarily like the rear switch or anything, but I understand the world we have created. Safety concerns and cost of manufacturing are often the two predominant traits when developing a product.
