Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
    Feb 2013
    24
    Default Whats with power switches on the rear?
    Is their some logic in the on/off power switch being on the rear of both my Miller 211 and the Hyperthern? Its a bit of a pain fumbeling along the back edge feeling for the switch. No big deal breaker but curious if anyone knows the logic to the rear?
    Feb 2011
    The GREAT State of Texas!
    158
    I can't tell give you the logic but it is inconvenient to say the least. I have gotten use to it but it took a while.
    Roger Troue
    Retired since 2004
    Miller 211
    Miller 200 Syncro
    Miller 375 Extreme
    Aug 2004
    Milan Michigan
    1,796
    I agree, They did it in my 2050 plazma and on my Dynasty.
    Cave Creek Az
    1,040
    Likely it is cheaper to make, less heavy gauge copper wire. Probably saves them $1.25
    Mar 2012
    Could be carry over from the Pow Con days. They are tough to operate. They say Miller bought Pow Con for the inverter technology.
    Feb 2005
    N.E. SD
    1,381
    Quote Originally Posted by walker View Post
    No reason to worry about the convenience to the owner... Or lack of.
    Lincoln did it on the Invertec also.
    Jeff
    Sep 2009
    Colorado
    223
    Default Saving a few pennies
    As a former manufacturing engineer, I think that saving a few pennies is the real reason. From a human factors issue, it is just bad design, no excuse for it. Many welders do have the power switch on the front, where it belongs.
    Richard
    Jul 2011
    Huntington, NY
    118
    Highly Phuking annoying. Couldn't agree more.
    Houston, TX
    900
    The switch on my MM210 is on the front, but turned horizontal. NBD to me, but when it came out there was a lot of complaints.
    May 2011
    Bossier Parish La.
    550
    My MM140 has it right upfront where it should be. If it really bothers you, you could extend the wires cut a hole and mount it in front where you want it. But that may void the warranty then, not sure.
