This would make a lot more sense than buying something that is strictly a generator only. Either of these is a better choice, use wise, than a generator only type of machine. You can weld and/or generate with them. You could use it on the build to stick weld structural parts the MM211 may be marginal at doing, and the duty cycle and amp output is WAY higher on them than the MM211.
Results 11 to 11 of 11
Thread: MM 211 with a 5500W generator
03-05-2013, 08:12 AM #11
- May 2011
- Bossier Parish La.
- 384
