Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
    May 2011
    Bossier Parish La.
    550
    Quote Originally Posted by BD1 View Post
    ''i was thinking of buying a 10000 watt generaor for the build which i still might do cause i can always use it for other things. thanks for the input.''
    What about getting a TRAILBLAZER or BOBCAT WELDER / GENERATOR ??
    This would make a lot more sense than buying something that is strictly a generator only. Either of these is a better choice, use wise, than a generator only type of machine. You can weld and/or generate with them. You could use it on the build to stick weld structural parts the MM211 may be marginal at doing, and the duty cycle and amp output is WAY higher on them than the MM211.
