Results 1 to 7 of 7
    Question miller papr system
    Hey just wondering if anyone has the PAPR system and can give some real world experiences with it. My shop is getting into more die welding and the stick electrodes were using were alot worse on fumes than I expected them to. be so after 3 days straight on one die my lungs aren't happy with me so I need to looking to a respirator system. So do you guys have any time under your belt using this system or another respirator system that would be worth looking into have more work lined up in the coming weeks and need to get something soon. None of my local LWS have one in stock that i can look at in real life and for that kind of $$ id really like to know its not being wasted when there's a better solution
    Leblond Makino mills
    HAAS CNC SL-40 lathe
    American Pacemaker lathe
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Miller Elite Vintage USA
    Mar 2010
    Ontario
    157
    I have the Miller PAPR!
    I THINK IT IS GREAT,I use it when im gouging,hard facing, and welding where the air movement isnt that great. Always come out breathing and feeling great!
    And the lens never fogs up.
    Battery last all day, well 8 hrs anyway.
    Waiting for my lws said they would work on getting a demo
    Model in before I buy
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Jan 2012
    Appleton, Wisconsin U.S.A.
    139
    Lightbulb Half Mask Option
    Keep in mind that this LPR-100 Half Mask Respirator might also be an option, fits right under your hood. No, it won't pump in any fresh/filtered air, but it will filter out the bad stuff. Might be good to have on hand as a backup if your battery on the PAPR runs down.
    http://www.millerwelds.com/products/...ion/half_mask/
    Angry Papr hard hat
    I just saw a miller brochure at my lws that had a papr hard hat and a standard hard hat adapter with the new style headgear that fits slotted helmets.
    SOMEONE PLEASE TELL ME WHERE TO FIND THESE ITEMS I WANT THEM NOW!
    Sep 2009
    Colorado
    198
    Default Papr
    I have a different PAPR system that I use when I have a lot of grinding to do. On one project I was grinding stainless for hours a day. As others have said, the steady air flow keeps the lens from fogging up. It gets kind of comfortable, although you look like a spaceman.
    My understanding that a PAPR is generally regarded as 10 times as effective as even a good filter mask.
    So, yes, I recommend a PAPR any time the fumes become an issue, and a regular filter mask does not seem to be enough. In some cases you could use a fume removal system as an alternative, but I don't think that most fume removal systems are as effective as PAPR.
    Richard
    finally got my LWS to get a miller demo in the shop the helmet and PAPR system works great. Its a pricy system but well worth it.
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
Tags for this Thread
