Results 11 to 20 of 24
    Feb 2013
    Canada
    110
    Default food grade stainless
    Copper will eat your heat"
    Sep 2012
    seaford de
    407
    OK... so you are all confused. For one if your welds are sugared on the back side you need more practice with stainless... as in speed up, and "food grade" is in the finish. It is less porous. You can get just about any stainless in food grade. And I know at one time all of us had to ask the same question!
    Feb 2013
    Canada
    110
    Weldonwelding,
    If you need full pen on your weld,and there is no purge or backing..no matter what speed you going at..youll get "sugar"
    So let say i have a piece of 309 stainless kicking around i can use that for food processing??
    Heuu...bignono!!
  4. #14
    Sep 2012
    seaford de
    407
    Quote Originally Posted by Rhinox:303064
    Weldonwelding,
    Heuu...bignono!!
    They make 304 food grade, 316 food grade, 200 series food grades, 400 series food grades... there are lots of food grades. The series doesn't determine whether its food grade or not. I have been welding in food process plants for about 15yrs, mostly chicken plants and when I first started I burned through quite a bit. It takes practice. But just cause your burning through doesn't mean you have to purge or use a back plate.. most cases your going too slow. In the food industry filler metal is hardly ever used on sheet metal (like were talking about here).
  5. #15
    Feb 2013
    Canada
    110
    ..mmm
    If you dont purge on the back u cant have a sanitary weld...unless you weld both sides...(or backing or purge) it cant have a joint without welds even pin hole..gotta be white...
  6. #16
    Feb 2013
    Canada
    110
    Specialy with beverage
  7. #17
    Jan 2013
    20
    I'm gonna purge them as I can't get to the back. It's thin material but I would still like some filler on hand incase I get a bit trigger happy. I know I'm gonna be using less than 30 amps and using a gas lense.
  8. #18
    Feb 2013
    Canada
    110
    Have fun use the pulse if you can
  9. #19
    Jan 2013
    20
    Yeah I will.
  10. #20
    Jan 2013
    20
    Job complete. Customer more than happy.
    Will have to change my purge setup tho.
    Using a Y piece in the gas line didn't work too well, had Little flow to my torch. Just enough.
