Results 1 to 7 of 7
    May 2012
    22
    Default Stick Welding Steel to Cast Iron + Clamp Mini-Project
    Goodmorning everyone!!
    So, this is my latest mini-project:
    Recently, I wished I had a way to tack things to the "inside" of my table... Too far from the edges to conventionally clamp them... And this is what I came up with...
    I bought a BESSEY 8" C clamp from the local lowes, spark tested it to determine it was malleable iron, and then cut if off and simply 7018'd it to a couple scraps of mild steel plate, which I can tack anywhere I need to...
    Anyway, the clamp welded very well... It was my first time welding malleable cast iron, and first time welding dissimilar metals...
    And I got another tool for the shop... I'm pretty happy with how it came out
    Just thought I'd share... I'm probably not the first one to come up with this idea... Hope you guys enjoy the video, and have an awesome weekend everyone
    Salem ,Ohio
    3,651
    Cool
    That clamp should be cast steel and weld just like carbon steel, so not really two different metals...Bob
    Nov 2011
    Near Denver
    21
    Good work stretch! Mind if I share it on diyweldingplans.com?
    Dec 2012
    Simcoe Ontario
    47
    Oh you just made a grasshopper /screw dog. They work real good for tacking on one piece of steel to align a butt joint or push an adjoining piece down tight.
    Feb 2007
    asheville n.c.
    595
    I have a few
    northern NJ
    1,565
    I have used cut off c-clamps for 25+ yrs. It's amazing the things I take for granted.
    MM250
    RCCS-14
    The only problem with your welding videos Lance is THERE AREN'T ENOUGH OF THEM! :-)
    You've really made my entrance into welding a lot more interesting and successful.
    Thank you and keep 'em coming!
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
