Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Aug 2004
    Milan Michigan
    1,418
    Default Phase converter for a shear
    I'm stuck with single phase 220 and am in the process of buying a hydraulic shear that has a 20 HP motor on it, What size phase converter do I need.
    I've talked to a few people and I'm being told that I need to go 1-1/2 times the size of the motor so I will need a 30Hp phase converter.
    Is anyone running a shear or press brake off a phase converter.
    Los Angeles
    2,635
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Feb 2009
    Lodi, CA
    1,126
    For a single machine, wouldn't it be easier and cheaper to simply change the motor? Since you are still buying single-phase power, only advantage to a phase converter I can see is the ability to buy other 3-phase equipment, and run them off the same phase converter.
    Aug 2004
    Milan Michigan
    1,418
    I've never seen a single phase motor bigger than 7.5 Hp so let me go and see.
    northern NJ
    1,565
    Isn't your overhead crane 3 phase? Or didn't that come about.
    MM250
    RCCS-14
    Sep 2009
    Colorado
    148
    Default Variable frequency drives
    In addition to the rotating converters, which I think you are referencing, there is an electronic alternative. Some Variable Frequency Drive units have the ability to change single phase to three phase. I think that would be a less expensive solution. With a VFD you can also incorporate soft starts, etc. You would have to do some research, and change some of the controls, but this is another approach. You don't need the variable frequency, but the unit would do what you want, just leave the frequency at 60 hz.
    There are companies that you could call and have them help you size a VFD.
    With today's electronics, I would sure look at an electronic alternative. But if you can get a 30 hp motor cheap that might be the way to go.
    20HP is a large motor, of course, so would need an appropriately sized rotary converter or VFD.
    Note that 20 HP at 240 volts is around 70 amps, and that does not include the start-up current, which could be 4 times the steady state current or more. Do you have 400 amp service to your shop?
    Richard
    Aug 2004
    Milan Michigan
    1,418
    Raferguson, I might be in trouble, I only have a 200 amp service thanks for the advise.
    JS fab, A problem with the single phase motor is that this machine has a powered back gage, I'm not sure if they are hydraulic or electric motors that operate that and single phase motors dont normally spin both ways like a 3 phase motor does.
    MMW. I'm working on the 4 bridge beams this week end, my end trucks are done,
    I'm starting on the 4 bridge beams this week end and my ( 4 ) 2 ton hoists were ordered yesterday. By the time I bought the festoon cable trolleys ( 64 ) of them, the chain container and because my beam is 6.75" wide I had an up charge for a wider trolley I spent a little over $ 3,000.00 per hoist.
    To answer your question no my hoists are single phase. I bought Harrington hoists which is what I have in the front shop and they have been working good for the last 6 years.
    Aug 2004
    Milan Michigan
    1,418
    Broccoli 1, Ya I looked at that site also, I left a message with the accurpress and still awaiting their call back.
    WY...armpit of U.S.A.
    636
    It may pay to build your own rotary phase converter as a VFD in the 20hp range for severe service like a punch press, shear or ironworker needs is going to run in the minimum of $4000 range. Even the rotary set-up is going to be devastating unless you have a cheap source for the 3-phase motor. The one good aspect of a VFD for your set-up would be it's ability to minimize the motor start-up inrush through the soft start feature. A large rotary converter could be started off a smaller pony motor to aleviate the initial amp draw demand. Best of luck.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    alabama
    715
    Wont help but 10 hp single phase motors are available.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
