    Feb 2013
    3
    Default miller bobcat 225nt blows f1 fuse?
    Hello, new to the forum. I have a miller bobcat 225nt with an onan engine. I have replaced the d4 diode and the f1 fuse. For some reason it keeps blowing the fuse. I have checked the r2 rectifier, also checked the new d 4 diode. Checked the capacitor and brush rings also.
    Feb 2013
    3
    Also meant to add....my idle control board popped, will that cause the f1 fuse to keep blowing?
    6,765
    Disconnect "E" from the idle board, replace the fuse, and see if it pops again.
    It may be a failed SR2, bridge, or failed exciter coil. Tough to call.
    Feb 2013
    3
    pulled the e terminal off....still blew the fuse
    6,765
    Well, that means a failed SR2 (unlikely but possible), or a failed shorted exciter coil. very likely and big bucks to repair.
