Frank
My preferred version of that would still be to put the tube on the other side of the angle where I could easily reach it to grind(could be that I have tools you don't?). To weld it as it is in your photo I would knock the corner off the pipe with the grinder so it would fit tight to the angle and run a bead on about 1/3rd of the perimeter on the bottom and whatever I could manage across the top on the other leg of the angle. I don't know exactly how much you are going to pull around with this but unless you turn green and really bulk up when you get angry(turn into the Hulk) you won't be able to pull those two welds off. The welds should then be easy to reach for grinding and if your fit is good the paint will cover the seam on the rest, if not bondo it. Or you could cut the upper leg of the angle back to the center off the tube and weld it there and radius the other leg of the angle to match the tube radius and weld. Also easy to finish I think.
Meltedmetal
Results 11 to 13 of 13
Thread: Filling a weld
02-28-2013, 08:28 AM #11
- Dec 2011
- 230
02-28-2013, 09:34 AM #12
- Oct 2012
- 46
The tube was the original handle from a work cart and it was held on by bent sheet metal brakets; I am just relocating it on my welding cart. I removed the old brackets and ground away the old welds; I am not doing that again. And I do not have any more tube.
I am happy with the welds on the sides you cannot see in the picture, they are plenty strong.
The lesson I learned here is that the inside face of the angle web is not parallel to the outside face. If I cut the end of the tube at a slight angle than the gap would not be so large. I would'nt mind welding the gap closed, it is just the grinding in the tight confines I am trying to avoid.
Do welders use rotary carbide burrs for this kind of thing?
Looks like a little filler work this weekend.
02-28-2013, 10:01 AM #13
- Dec 2011
- 230
Do welders use rotary carbide burrs for this kind of thing?[/QUOTE]
I do, but only when I can't get it with a 9" angle grinder cause they are slow by comparison. Effective but slow.
Meltedmetal
