Results 1 to 5 of 5
    Jul 2012
    Houston,tx
    119
    Default Bernard q 400 question
    I have a question about the Bernard q400. I recently order it for my miller suitcase 12vs as I was reading more into the gun it says that it's setup for .45 wire my question is will the q400 run .35 wire(which I just bought a 44 pound spool of .35 wire
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    With it being a 400 and set up for .045 wire means that the liner is probably an .045 - 1/16 and the contact tip is an .045. The liner and the tip is big enough to run .035 through, but you might want to get .035 contact tips. Although I have used .045 tips to run .035 wire many times with no problem.
    Just curious, if you are going to be running a small wire like .035 why didn't you get a 300 instead??
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Feb 2007
    asheville n.c.
    595
    I had bernard with 5/64 liner. Ran everything from. 045 to 072
    Jul 2012
    Houston,tx
    119
    Because I got a real good on it and couldn't pass it up
    Jul 2012
    Houston,tx
    119
    So I just have to change the tips to run .35 wire right
