I'm repurposing some pipe. It will not function as pipe anymore. I need to remove the green coating efficiently. Rapid strip wheels on the grinder are going to take forever.
Is the coating made from epoxy?
Results 1 to 10 of 13
Thread: removing green coating
02-26-2013, 03:41 PM #1
- Nov 2012
- Northern Arizona
- 269
MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
02-26-2013, 05:10 PM #2
- Feb 2004
- 1,160
It's a sprayed on epoxy coating, meant to last a long time underground. There isn't a fast/easy/cheap way to remove it. Wear a mask if you have a lot of it to do.
Bare pipe would in the end be cheaper most times. Free, coated pipe involves a ton of labor and consumables to make it clean & bare.
You can burn it first, but it's still a lot of work/expense.
JTSome days you eat the bear. And some days the bear eats you.
02-26-2013, 06:47 PM #3
- Nov 2012
- Northern Arizona
- 269
Hey neighbor!
That is what I was afraid of. I don't have too much, but a couple hours worth of grinding. The funky wire wheel I was using was effective, but it was easily used up.MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
02-26-2013, 07:38 PM #4
- Feb 2013
- sault ste marie, canada
- 3
just a thought
do you need the whole pipe cleaned off? if not, just clean where your going to weld.
02-26-2013, 07:56 PM #5
- Nov 2012
- Northern Arizona
- 269
That would work, but then the finished product will not look perfect! Just a looks thing.
MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
02-27-2013, 04:01 AM #6
- Dec 2007
- alabama
- 718
you can chip it off a lot easier than burning or grinding.
XMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
02-27-2013, 09:11 PM #7
- Feb 2004
- 1,160
02-27-2013, 10:45 PM #8
- Nov 2012
- Northern Arizona
- 269
Haha me too! I made quick work of it with a 40-grit flap wheel to take most of it off and then clean it up with a quick strip disc. I was hoping for a chemical that would do all the work for me,sort of like removing hot roll mill scale...
MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
02-28-2013, 06:17 AM #9
Did you try a needle scaler?
03-01-2013, 11:59 AM #10
- Nov 2008
- Troy, OH near Dayton
- 43
That green or red epoxy is a mother to get off. Here's what I know works best.
If you can, heat the inside of the pipe to 300F - 350F. The epoxy on the outside will soften and peel off with a putty knife. You can clean up the exposed surface with a stripper wheel or flap disc.
If you can't heat the inside of the pipe then you can apply heat to the outside with a weedburner or rosebud. BUT, you need to be very controlled with the torch. The coating will scorch and the smoke smells terrible; it's probably not safe to breath either.
Heating the inside is best. If you don't want to use a putty knife you can use a wire cup or brush. BUT, you don't want to make a bunch of airborne dust out of the epoxy either. I have been told by a reputable source that breathing the dust is also very bad for you.
If you must grind, you and a friend should where particulate filters and use a shop vac with a good filter to collect as much of the dust as possible. Again, I don't recommend this at all. Much better to soften the coating with indirect heat and peel it off in large pieces.Benson's Mobile Welding & Fabrication
www.bensonmobilewelding.com
Serving the Dayton, Cincinnati, and Columbus, OH metropolitan areas
