Results 1 to 10 of 12
Hybrid View
    Jan 2011
    3
    Default Exhaust Fan Advice
    Hi! I have had a miller dynasty for over 2 years now, and im trying to get myself a good set up in my shed for hobby work. Im insulating and running wire as of now, so before i close up the walls i want to have everything wired and ready to go. I will mainly be tig welding aluminum, but id also like to pick myself up my own mig machine. I also work on Atv's and motorcycles in here and every so often will run them. From what i've read tig doesnt produce fumes on its own, but from contaminants. Basicly i want some advice on what size exhaust(CFM wise) i should go with. In the summer if im mig welding ill open the double doors, but in the winter id like to be warm. My welding space is a 12x9x8. Two single pane windows and a double door. I was going to pick up a broan 180 CFM fan, but im not 100% sure its sized for the job.
    Thanks for your help and time,
    Mike
    May 2011
    Bossier Parish La.
    385
    That fan would be a start on the ventilation, maybe installed near the work bench where you do most of the welding. If it proves to not be enough sometimes, then you could put a box fan in one of the windows(or both) blowing out. Just use them as needed to supplement the Broan, other times you could have it keeping you cooler in the summer.
    northern NJ
    1,565
    With that fan you will be replacing the interior air about once every 5 minutes. Being a small space I would say yes it will work as tig does not produce much if any "smoke". Don't forget you will need to crack a window or put a vent in elsewhere to let fresh air come in. Worst case open the window & door if it is really bad. Don't forget you will be sucking out your heat also.
    12x9x8= 864 cf /180cfm = 4.8 minutes
    MM250
    RCCS-14
    Nov 2012
    Northern Arizona
    269
    Hey Mike-
    bistineau has some good points. I like to have the fan pulling air away from the welding area as close as possible. If you are trying to keep it warm then you can get away with a lower cfm fan and pull the air as close as possible that you are not interfering with the shielding gas. Also mounting a fan up high can work well in the summer as you can get extra heat and welding smoke out of the building.
    Check out this fan for near the table. I think you could mount it in the wall and then run a flexible duct down to your welding area with a device to position it in the right spot.
    http://www.ebay.com/itm/280888077583...84.m1423.l2649
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    Dec 2011
    230
    Don't know how tight your room is but in a room that small keep in mind that not only does your shielding gas not support combustion it doesn't support life either. You might want to look at infrared heating and be sure you ventilate enough.
    Meltedmetal
    Feb 2013
    NJ
    16
    I have a shop in a 10'x9'x8' shed, my fix for ventilation was a shop vac placed outside with a flexible hose running in with a collector on the end, I place it anywhere on the bench where I'm welding.Not only does it remove the fumes, when I'm done working I vacuum up any slag and dust that I've created.
    Jan 2011
    3
    Thanks for all the advice fellas. I ended up getting a 250 cfm inline fan with speed control. Right now as far as heat i have 2 space heaters, which ill probably upgrade to a single unit eventually.
