Results 1 to 3 of 3
    Dec 2010
    355
    Default idoling uo or down when welding
    i use my bobcat alot for road jobs and aluminum welding. i normally run it to when i'm not welding it will idol down but just recently i was told that if i don't run it at high idol it will burn the reostat out. now i have been welding with it like this for over 4 years an never had any problems.what do you guys think
    1,890
    I have run my trailblazer like that for years without any problems. If I'm going to be running rod after rod or cac I put it on the "rabbit" position. If I'm going to be fitting, grinding with a few welds I leave it in "turtle" position. When my feeder is plugged in it automatically goes to the weld setting.
    Default Bob cat 225 g ...serial no kc 316991..
    Hi ...I have a related problem with my bobcat 225 g ( not sure of the year of manufacture ) serial no kc 316991....for the past 12 months it has started to "rev" up on its own after it gets hot ...which takes about 5 mins ...does any one here know why it is doing this ??.. the solenoid on the carburettor that rev's the engine up after i strike the arc ...or plug some thing in to the power point ...now is operating on its own ....its a nuisance ...it is doing this every few seconds ...maybe some one has had a similar experience ...I know it works by sensing electrical drain ...the battery is new ...thanks in advance
    johny
