Results 1 to 10 of 11
    Feb 2013
    2
    Default welding aluminum with the spoolmate 100
    I recently purchased a Millermatic 211, and also got the spoolmate 100 spool gun to try some aluminum welding. The welder works awesome on the steel projects i have done, but i cant seem to get the spoolgun to work like i want. I have a hard time getting a puddle to form, the wire seems to burn up before it hits the metal. I have tried the settings recommened on the machine, and tried extreme settings but it doesnt seem to change much. When i leave the wire out about 3/4", it seems to just dissapear when i pull the trigger. I used .030 5356 wire at first, but switched to .030 4043, which seems to be better in that i can sort of leave a bead, but still cant see a puddle or wire, just a glow. I am using 100 % argon gas. I am trying to weld 1/8" thick aluminum sheetmetals and sqare tubing. Any information is appreciated. Thanks.
    Try turning the thickness to 3/8, & wfs to 100.
    turbo38t Guest
    Not too familiar with that spoolmate but on a spoolmate 30 I think I ALWAYS start out with my voltage on 5 or so and keep my finger on the wire/amperage adjustment and start out with TOO much wire and then back it down. Also, make sure you are using 100% argon....NO C25....I almost always push the puddle with a spoolgun
    Quote Originally Posted by jhamm75 View Post
    Oct 2004
    Edmonton, Alberta
    8,227
    This has been posted more than few times, try a search on the Spoolmate. It all comes down to a tip issue for this model.
    northern NJ
    1,910
    It sounds like your wire feed is not high/fast enough. Also there is issues with the tips.
    MM250
    RCCS-14
    Feb 2012
    226
    Wire feed speed check your manual what kind of wire speed they have on the newer units not as fast as they used to be don't ask me how I know.
    Feb 2013
    2
    Thanks for the replies everyone. Ill do a search on the spoolgun.
    Feb 2012
    226
    460 Ipm on 211 auto set is tops I have a older 140 that will do 600 Ipm a little bit of difference the 140 has got plenty wire speed but not enough heat for aluminium millermatic 252 700 Ipm tops
    Los Angeles
    2,932
    I didn't have any problems with the tips provided.
    AL can be frustrating - everything needs to be set up precisely, any minor change has a major effect😜
    Push while welding al.
    Stick out
    Contact tip to work distance- the distance between the end of the wire and the work
    Check the drive roll tension on the gun
    Once arc is established you gotta boogety boogety as it is a lot faster than welding steel.
    The bottle of Argon could be contaminated
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Jun 2009
    las vegas
    227
    Use 035 instead and up your speed if your using the 30
    Millermatic 210
    dialarc 250
    spectrum 375x
    trailblazer 302
    Lincoln 135
