Results 1 to 5 of 5
    Feb 2013
    24
    Default extension cord from an RV cord?
    I have a 50 foot 30 amp 10 gauge RV ext cord. If I cut the RV ends off and put on welder plug ends will it work OK on a Miller 211 on 240 volts? Way cheaper than anything else I can think of and as far as I know 10 gauge should do it?
    Los Angeles
    2,927
    That will work fine for the MM211
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    May 2012
    110
    Quote Originally Posted by gsims View Post
    Response I believe I received from miller was 10 gauge for 50 ft and 8 gauge for 75 feet as a guideline......
    Miller Thunderbolt 225 AC/DC
    Millermatic 211 Auto/MVP
    4,446
    Depends onthe machine, the 211 would run on 200 ft of 10.
    Aug 2012
    Hermiston Oregon
    279
    It'll work
    I've got two 50'
    I swapped plugs on
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
