Results 1 to 7 of 7
    Feb 2013
    2
    Question Fittings on Oxygen Supply Line
    Can galvanized fittings be used in an oxygen supply line? The gauges on my oxygen tank are too low for me to read and I want to arrange them so they face up rather than forward. Brass fittings cost 3 to 4 times more than galvanized.
    4,246
    Twist the regulator and position it easier to see before you tighten it.
    Apr 2009
    not near you
    130
    All fittings used in fuel gas and oxygen lines should be of a non-sparking material...
    northern NJ
    1,565
    Quote Originally Posted by bayweld View Post
    Follow this advice. Three to four times the cost in this instance is only a couple dollars. Brass is also a soft material so it seals better & less chance of ruining the regulator body.
    MM250
    RCCS-14
    Default brass
    as you have been told and i agree. use only brass.
    the reason is safty. any spart generated by anythink like steel could cause harm,to you.
    yes they cost more,or do you what to be hurt or injured or worse?
    do what is safe.
    Sep 2012
    seaford de
    331
    Quote Originally Posted by Sberry:302542
    I second that... makes sense.
    Feb 2007
    Near Dallas, TX
    214
    Be sure you get fittings rated at the proper pressure if you're also modifying the high pressure gauge.
    I don't know what the specs are for oxygen service, but I imagine the brass is used for corrosion resistance. I don't know how well the galvanized will hold up. It may quickly corrode all the zinc, and then start attacking the steel.
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
Tags for this Thread
