Results 1 to 10 of 10
Thread: Bandsaw Welders
    Default Bandsaw Welders
    What are the capabilities of ideal band saw welders?And Is it possible to join bandsaw blade using TIG welding ? I know that it's not a good way though.
    Nov 2010
    265
    The Ideal fusion blade welding process is a very small part of the entire bandsaw manufacturing process.
    Jan 2013
    28
    I have had no issues mig welding 3/4 and 1" new blades for my Kalamazoo
    bandsaw ,not ideal but have not broke one yet ,
    Jan 2009
    SW Ohio
    135
    Not sure what you're looking for, but there's nothing wrong with welding bandsaw blades with TIG, but you still need to temper the weld with a torch or other heat source. The blade welder just provides a quick way to do the job ... fixturing, welding, tempering and grinding all in one machine.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    Dipsomaniac, have you tried joining band saw blades?
    Forger, what are your blades?
    4sfed - have you tried tig welding on band saw blade?
    Jan 2009
    SW Ohio
    135
    I have a blade welder for the 1/2 in blades on the contour saw, but TIG weld my 3/4 in blades for my cut-off saw.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    Nov 2010
    265
    I own a Wood-Mizer saw mill that we had two (carbide tooth) blades made from existing Double hard stock blades. The heat treatments and finish grinding are the most critical aspects.
    Jan 2013
    28
    Quote Originally Posted by surfside View Post
    Sorry my blade is 3/4" not 1" as I stated, 3/4" x 10'6" on a Kalomazoo 8" x 16" As I bought this machine used several years ago ,it came with a couple of dozen NOS blades kinda of rusty but never used,most of the blades were meant for an 8" x 24" so when I need a new blade I chop saw one down,wire weld (Mig) .035 back together,peen the weld over the anvil,grind it smooth and back in buisness.Most of my cutting is on A36 mild steel(whatever they make that out of these days )I cut dry but do use wax or W40,I don't have any employees so I am the only one who uses the saw,(I baby it)but do use the hydrualic cylinder to let it cut.I wear them out but don't break them.Differnet subject,any one else notice how you can put a temper in mild steel these days?Never use to be able to do that.Must be those Yugo bumpers the have been recycling
    I have couples of bi metal and carbide blades. But they are all great. I was just wondering, I watched TIG welding videos on youtube and I was in doubt if it's possible to apply it on saw blades. Anyhow, what could be normal method that band saw welders do in joining blades?
    Putting temper - preheated oven with over 200 degrees Cor I guess;;would that work?
    Jan 2009
    SW Ohio
    135
    Only the tips of the teeth are carbide/hi-speed, the band is carbon steel. After welding, it needs to be quickly cooled to transform to martensite, then tempered to keep it from being brittle.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
