I recently bought a miller suitcase extreme 12 vs im planing on doing a lot of welding on trailers about 3/16 -3/8 thick and other projects mostly having to do with 1/4 -1/2 inch steel my question is I have a .35 spool and running c25 do y'all think that's a good combination (by the way I'm running the suitcase of my bobcat on cv power ) any input is much appreciated it
02-18-2013, 08:04 PM #1
- Jul 2012
- Houston,tx
- 119
miller suitcase extreme need advice
02-19-2013, 05:06 AM #2
Are you going to be in a shop or outside? If outside I would look into an innershield wire.
I usually only run .035 on 1/4" & thinner material. Next step would be .045.MM250
02-19-2013, 06:28 AM #3
I will second that question by MMW. If you are gonna be outdoors running an outershield wire, especially a c25 wire, you are gonna have to use ALOT of gas to maintain coverage in outdoor conditions. And c25 can get expensive.
If you are gonna have to be outside, as MMW suggested, look into the innershield wires. If they will work for your applications, you might wanna use that. If you are not comfortable running innershield, it does run different than outershield, I would suggest an outershield wire that is used with 100% co2. That is much less expensive than bottles of c25.
And the .035 or the .045 size is acceptable for your applications.Last edited by jpence38; 02-19-2013 at 06:32 AM.
JIM
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
02-19-2013, 06:56 AM #4
- Jul 2012
- Houston,tx
- 119
I'm going to be welding inside my garage I was just kind if worried about the .35 wire not been able to handle that kind of thickness, so do y'all suggest me running c02 with the .35 hardwire(kind of getting tired of cleaning up all the splatter from the inner shield flux core and thanks for you inputs
02-19-2013, 07:44 AM #5
- Feb 2012
- Wa
- 315
Hard wire with c25 will have least amount if spatter. At least in my experience.
02-19-2013, 08:10 AM #6
- Oct 2011
- 40
wire
I run c-10 gas and tri-mark .045 metal core in mine. It welds very smooth with very little splatter. It's very easy to tune in as well for thin or your thicker materials
ARMOR
MOBILE WELDING&SERVICES
Trailblazer 302
X-TREME 12VS
Spoolmatic 30A
Millermatic 135
WeldCraft WPseries TIG torch
Smith oxy set.
02-19-2013, 12:15 PM #7
Sorry about that juancarlos20121'
I assumed you were using a flux-cored wire. I have always had good luck with the 75/25 and solid wire. Since you will be indoors, I would stick with that. You might also pick up a roll of .045 and give it a try. That way you will have both just incase. But I think you would do just fine with the .035JIM
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
02-19-2013, 02:54 PM #8
- Jul 2012
- Houston,tx
- 119
Thanks everyone for the comments
02-19-2013, 03:59 PM #9
- Feb 2007
- asheville n.c.
- 595
I use 212 .045 wire inner shield, i don't notice any spatter. Haven't really paid any mind, but i use on hand rail. Running it out of ln 25 and tb 302
