Results 1 to 10 of 11
    May 2008
    Troy, MI
    377
    Default Weldment for FIRST Robotics 2013
    For 2013, the FIRST robotics game is to shoot Frisbees through various targets and to climb up a 10 foot high pyramid. Our team’s first task was to make the team version of the pyramid. The team version is made of materials that are easy to get such as 1-1/4” pipe, with the corners clamped using U-bolts and plywood. One of our concepts was to have the robot climb up the corner of the pyramid, so we had to build one corner of the competition pyramid, which is slightly different than the team version. The competition version of the pyramid is made of 1-1/2” tubing which has an OD of 1.5” as opposed to the 1-1/4” pipe used on the team version that has an OD of 1.66”. We didn’t want any surprises when we entered our first competition. I made all of the parts for the competition corner and welded them together. We attached the competition corner weldment to a wall for support. Attached are some pictures of this project.
    A few notes:
    • The swivel mast horizontal saw worked great to cut all of the angles of the tubing, which is shown in picture 2.
    • Picture 3 shows the 1.5” drill bit installed directly in the ¾” R8 collet of the milling machine, to save lowering the knee of the milling machine and requiring the use of a ¾” ball bearing chuck.
    • I didn’t have a 1.5” diameter end mill to mill the 1.5” slot, so I bored the hole and stepped over about 0.040” for each bore as shown in picture 4. You can hardly see the steps in picture 5. (The large diameter with the relatively small steps averaged out the steps.)
    • I used an outside corner end mill to make the ¼” radius on the floor bracket shown on pictures 6 & 10.
    • I used two saw horses plus an adjustable table to support the weldment shown with my friend Bill in picture 12.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    377
    Default Weldment for FIRST Robots 2013
    Some more Pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    377
    And the last few pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Apr 2010
    318
    So, how did the robot build come together? Does it climb OK?
    May 2008
    Troy, MI
    377
    Quote Originally Posted by USMCPOP View Post
    The shooter is awesome.
    We can get 16/16 Frisbees in the goal shooting the length of the field.
    We are still working on the climber.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Apr 2010
    318
    I may stop in and see a bit of the Virginia Regional at VCU next week. Sounds like an interesting game this year.
    That was an excellent process! You must have enjoyed it.
    Apr 2010
    318
    Shameless plug:
    If anyone out there wants to help out these kids and the FIRST Robotics program, it's a good deal. I was a mentor for five years, helping our local high school team put together a drive train with (mostly) cordless drill motors, sprockets and chewing gum. Never had one fail. The last year I did it, the team earned a Motorola Quality Award at a regional competition.
    I worked with a lot of kids and we had some great times and some not so good. We all learned. Sometimes we learned how to make things. Other times we learned how to get along, or share disappointment. The robots we made lasted a lunchtime but the memories a lifetime.
    Apr 2010
    318
    Here's a vid of this year's action:
    http://www.youtube.com/watch?v=uTo9c7qv6is
    wisconsin
    116
    Thats really cool.
