hey all
Is anyone using air line quick disconnects for argon lines? I decided to try some and wasn't sure how to test if they leak except for placing them in a bucket of water. I don't really see any bubbles. Would these leak over time? Or are they are pretty reliable? thanks
I made a video if anyone wants to see
Results 1 to 10 of 14
02-18-2013, 12:21 PM #1
- Dec 2012
- 8
using airline quick disconnect for argon line?
02-18-2013, 03:12 PM #2
I use Parker 200 series quick connects for my spoolgun/mig gun hook up. No problems over the 5 years i have had them on....Bob
02-18-2013, 03:22 PM #3
- May 2011
- Bossier Parish La.
- 385
Spray it with some soapy water to better check for leaks, watch for bubbles.
02-18-2013, 04:07 PM #4
- Dec 2008
- 14
I have had them on my Dialarc for years with no problems or leaks, yes I am cheap,I had them, tried them and they work.
02-18-2013, 04:10 PM #5
You can use them, Milton is a well known name brand verses the big box store ones.
However, they are not as good as say a western which is what I use and I have them on all my suit case feeders and torches so we are talking about 8 fittings over the last 21 years that I have been using them.
With the cost of mixed gas at around $ 45.00 its not worth it to me, Your better off bucking up and spending the money.
02-18-2013, 04:45 PM #6
- Feb 2009
- Lodi, CA
- 1,126
It takes less inert gas than you think, to make a life-threatening situation, especially in a small garage/shop. There is a reason some connectors are rated for air, others are rated for flammalble/oxidizer/inert gases. Use the correct connector for the purpose it was designed for.
02-18-2013, 04:51 PM #7
Are those rated for that pressure
02-18-2013, 05:23 PM #8
- Dec 2008
- 14
Mine is between the machine and the torch, low pressure and only under pressure when I am on the pedal.
02-18-2013, 05:40 PM #9
- Dec 2012
- 8
02-18-2013, 05:43 PM #10
- Dec 2012
- 8
ok i'll check out those parker or milton
