Results 1 to 10 of 14
    Dec 2012
    8
    Default using airline quick disconnect for argon line?
    hey all
    Is anyone using air line quick disconnects for argon lines? I decided to try some and wasn't sure how to test if they leak except for placing them in a bucket of water. I don't really see any bubbles. Would these leak over time? Or are they are pretty reliable? thanks
    I made a video if anyone wants to see
    3,861
    I use Parker 200 series quick connects for my spoolgun/mig gun hook up. No problems over the 5 years i have had them on....Bob
    May 2011
    Bossier Parish La.
    502
    Spray it with some soapy water to better check for leaks, watch for bubbles.
    I have had them on my Dialarc for years with no problems or leaks, yes I am cheap,I had them, tried them and they work.
    Aug 2004
    Milan Michigan
    1,633
    You can use them, Milton is a well known name brand verses the big box store ones.
    However, they are not as good as say a western which is what I use and I have them on all my suit case feeders and torches so we are talking about 8 fittings over the last 21 years that I have been using them.
    With the cost of mixed gas at around $ 45.00 its not worth it to me, Your better off bucking up and spending the money.
    Lodi, CA
    1,192
    It takes less inert gas than you think, to make a life-threatening situation, especially in a small garage/shop. There is a reason some connectors are rated for air, others are rated for flammalble/oxidizer/inert gases. Use the correct connector for the purpose it was designed for.
    Feb 2013
    12
    Question
    Are those rated for that pressure
    Mine is between the machine and the torch, low pressure and only under pressure when I am on the pedal.
    Dec 2012
    8
    Quote Originally Posted by Renagade View Post
    They are rated for 300psi
    Dec 2012
    8
    ok i'll check out those parker or milton
Tags for this Thread
