    Feb 2013
    3
    Default Blue Star 2E part needed
    Howdy all, first post here, But I am in search of a part that I gone and done busted.
    I need the rotor adapter plate that goes onto the engine crankshaft as I busted the one I had trying to get it to pop off the taper. I am hoping maybe someone has a good used one? part number I need is 021-934 engine is a OH160 16HP Tecumseh. Miller Welder is a Blue Star 2E
    Any info or leads to a good part would be much appreciated!
    Thanks, Shawn
    Feb 2013
    3
    nobody?
    Jul 2010
    Four Flags city
    304
    Feb 2013
    3
    yikes!!
    Hoping to find someone that had a good used one maybe?
    May 2011
    Bossier Parish La.
    560
    You could check with a local small engine shop that deals with Tecumseh engines. Have the broken pieces with you so they can see what it is supposed to look like. Worth a shot. Or find someone that can weld it back together for you. It might need a little machine work afterward.
    226
    We're are you located there's a old fellow over here that works on welders keeps a lot of old stuff around there I could call him if you don't find anything he is kinda grouchy but he is good and may have something he is in north zulch tx
