    Dec 2012
    Sweetwater, TX
    195
    Default Why no welding cover specific for the CST 280 ?
    I like to take care of my equipment when it is stored and really like the cover I have for my Millermatic 140c mig welder.
    I have been looking at the CST 280 for a stick welder and making a list of all the accessories I will need to get but I don't see a cover that is mentioned to fit it.
    The Maxstar 200 is 17.5" long while the CST 280 is 18" long. The Dynasty 200 is 21.5" long which seems way too long.
    So I'm not sure how tight the tolerances are on the covers and if the one for the Maxstar 200 will fit the CST 280 or if it will be too tight?
    Anyone know which Miller cover will properly fit the CST 280?
    Thanks!
    WY...armpit of U.S.A.
    640
    I've no specific answer for your welder, but when I needed one for my Lincoln TIG and one wasn't available I headed over to the nearest upholstery shop and had the gal fab one up out of heavy Cordura. Cheaper than what was available...or in this case, not available...and a custom fit that even has the provision for the Argon tank size I am using. so, if you can do without the logo, it might pay to hit the upholstery shops in your area.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Raymore Missouri
    1,910
    A $10 beach towel will keep the crap off
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jan 2008
    northern california
    318
    Default machine is the same size.
    The maxstar cover should fit. The cover does not have "maxstar" printed on it. The maxstar200 and cst280 seem to share the same case. If you are that worried ask Miller to try the cover.
    Ornamental fabrication shop worker
    at home...
    2011 Hobart Handler 210
