need a little info. on welding magnesium. got a transfer case with pin holes it's magnesium thanks for any info.
Thread: magnisium
02-15-2013, 05:36 AM #1
- Mar 2009
- kingsport tn.
- 43
magnisium
02-15-2013, 08:04 AM #2
- Oct 2009
- 254
Same as aluminum. Use magnesium filler
and wp2025 weldcraft torch
Miller 125c plasma cutter
02-15-2013, 08:55 AM #3
- Nov 2012
- 4
magnisium
Any chance this is the chevy pump rub issue? If so i got mine fixed just with some jb weld and a spacer plate. Been solid for over a year now
02-15-2013, 09:34 AM #4
- Nov 2012
- Northern Arizona
- 269
MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
02-16-2013, 07:34 AM #5
- Mar 2009
- kingsport tn.
- 43
yea a guy brought it 3 bb size holes at out put shaft side in the locking notch's said chevy would not honor the fix. yeah has to be out to fix to clean oil out heated it with a small propane torch and wire brushed it clean welded good
02-16-2013, 08:41 AM #6
- Dec 2011
- 230
Is there room to tap the holes and put screws in? Could save a lot of work if it can be done.
Meltedmetal
02-16-2013, 10:45 AM #7
- Nov 2012
- 4
magnisium
I believe the mechanic did pull the case off. Had to to intall a spacer plate inside so it quits rubbing. Mine was caught during an oil change and it must have just poked through. Maybe a diameter of 1/8 if that.
02-16-2013, 05:27 PM #8
The cheapest magnesium filler I could find was $85 for a half pound from McMaster-Carr.
Dynasty 300DX
MM350P
Hobart Handler 120
Smith LW7, MW1, AW1
Smith AR/He Mixer
02-16-2013, 06:45 PM #9
- Mar 2009
- kingsport tn.
- 43
air gas was 97.00 for a #1 (minimum 12#) went to a shop and a great guy gave me 2 stick's
