Is there anyway to reduce post flow on maxstar 150STH? i am wasting a lot of gas on random projects.
02-14-2013, 10:05 PM #1
- May 2007
- Los Angeles
- 116
Reduce Post flow gas Maxstar 150sth??
02-15-2013, 01:43 AM #2
- Jan 2009
- 19
I believe it is pre set. How much do you think you are wasting? Post flow helps protect the weld as well as tungsten. I figure if it's gonna flow, its gonna flow on the weld where it will help.
02-15-2013, 02:37 PM #3
- Oct 2012
- 5
I think the gas post flow is pre-set depending on the amps your running, the hotter you weld the longer the post flow. I have the same problem. Also does anyone have issues with weak HF?
02-15-2013, 04:53 PM #4
Turning down your CFH to a bare minimum will help.
Sometimes when I'm tigging heavy pipe I actually wish it would stay on a hair longer so Miller had to meet in the middle so ya it stays on a little longer than need be when welding on certain things.
Keep in mind I'm not complaing, Its a great machine.
