Results 1 to 10 of 10
    Jan 2013
    Nebraska
    15
    Default stainless steel mig welding
    I have never welded stainless before but I might be faced with it soon. Any tips? Pointers? Things to expect ? Thank you
    northern NJ
    1,589
    Make sure you use a trimix gas.
    MM250
    RCCS-14
    Jan 2013
    Nebraska
    15
    What kind of wire is best? I know between .030-.045 in size
    Nov 2007
    Central Idaho
    191
    Not to overstate the obvious, but you will need stainless wire, probably 308 - it depends on the parent metal alloy. Size, of course, will depend on thickness of material and amps.
    Stainless warps like crazy when heated, so clamp, clamp, and then clamp some more.
    What he said about tri-mix gas.
    Nov 2007
    Central Idaho
    191
    Two more thoughts - stainless wire is not required for welding stainless, but if you use regular E70[xx], then the weld itself will rust. Also, depending on the structure of what you are welding, back purging may be necessary to prevent contamination. A thread search will tell you all you need to know about that.
    Jan 2013
    Nebraska
    15
    Dec 2009
    722
    are you welding SS? we weld on dipper buckets parts made of manganese with 309 and use C25 and it is the same way as any other fluxcore, use the voltage specified and adjust your wire speed.
    Jan 2013
    Nebraska
    15
    I haven't welded stainless yet, the opportunity might be coming though
    Mar 2009
    Michigan
    138
    Default ss wire
    i would suggust getting the L Si in the wire, So if 308 L Si, 309 L Si, or 316 L Si, it will run much smother.
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
    Feb 2007
    Ukiah, Ca
    277
    I just did some SStl MIG at work, and I must add that out of position welds suck, just like using 308 stick.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
