Results 1 to 10 of 15
    Default Aluminum TIG welds
    I don't have much experience with Tig welding aluminum. Can you guys look at them and help me a bit on how I can improve?
    Oct 2009
    306
    Just from what I see without knowing your setup or parameters. It looks a little cold and not uniform, there are several spots in the last pic where the tungsten was contaminated or dipped in the weld puddle. Keep practicing to get your timing for dipping the filler into the leading edge of puddle and advancing the torch forward so that it is second nature and you don't need to think about it.
    When you sitting infront of the TV, throw a tig glove on your filler rod hand and practice feeding the wire until you can do it without a second thought. That and more arc time. You'll get the hang of it.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Aug 2010
    Los Angeles
    1,173
    ^^^^What he said.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    The machine is a diversion 180. Set at 180 amps. the material is 6x4x1/4" tube. I tried preheating the aluminum. I guess I needed more heat.
    looks like u need your machine cranked up maybe 10-20 more then u can run a little faster and it outta lay right in there bud
    Feb 2013
    1
    Your welding machine is only rated for 3/16" aluminum. For 1/4" you need 190-220 amps. I would recommend getting some thinner sheet metal for practice.
    northern NJ
    1,910
    Did you bevel the pcs. first or just trying to butt weld them? Aluminum bridges very easily so it is easy to get a good looking weld on top with almost no penetration. Just something for you to watch out for.
    MM250
    RCCS-14
    Feb 2012
    561
    You need more HP and like MMW said be sure to bevel your but welds, it will not only allow for better penetration but will also help with the lack of power. Try cleaning the aluminum real well and raising the A/C bal, that will also help with lack of power.
    Aug 2010
    Los Angeles
    1,173
    You could try mixing some helium into your argon. Or rent a 75%argon/25%helium premix.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    The material was beveled and brushed clean with a stainless brush. I am using 75/25 mix of helium. I just dont think the machine has the amps for 1/4".
