Results 1 to 3 of 3
    Jan 2003
    33
    Default pulse control Syncro 180
    some guy told me about this aftermarket "pulse chip" for the syncrowave 180! i think the guy who told me that is wrong so i did some looking... and this what i found, if you scroll down to pulse control what is "yes,(pc 300)" i thaught the syncro 180 cant pulse? well anyways here it is
    http://www.millerwelds.com/products/...ve_180_sd.html
    can you get external pulse control for any tig welder that doesnt have intenal pulse? or how bout just for the syncro 180?
    Feb 2006
    3,711
    Default TIG Pulse control
    According to the 2003 Miller Catalog (page 79), the PC-300 can be used with AC or DC welding power sources with, or without, built in high-frequency or with external high-frequency units (for example,HF-251D-1). This wording is copied directly from the Miller Catalog.
    Jan 2003
    160
    HI JWD..............THE PC-300 WORKS BEST ON DYNASTY'S, XMT'S, MAXSTAR'S, ETC.......... It will work on the syncrowaves.... and it will work on the 180sd.......... cost is in the $700.00 range....... For the cost it might be better to purchase one already in a unit.... Just my thoughts..............Rock..................
    SSCOTT@MILLERWELDS.COM
    ROCK
